refeer ventalation fan
cleojayco
when do you use the ventilation fan on the fridge seems like when it's running it does not get cold
6 REPLIES 6
cleojayco
1 problem I was running the fan the temps were mostly in the 70s
temps in the fridge & freezer were good with fan off.Beer was not getting cold and things in the freezer were only semi froze when fan was on
dometic auto temp control
fridge is in a slide
the trailer is a 2014 evergreen
Old-Biscuit
cleojayco wrote:
yes above the fridge access from outside
yes on off switch
75
weeks
Fan should only need to be run when air temps are above 85*F
W/O Fan ON........what temps are you getting freezer/food sections
What Brand/Model of Fridge?
What Year?
IS fridge in a slide out?
cleojayco
yes on off switch
75
weeks
Old-Biscuit
cleojayco wrote:
the fan is a separate switch when we had the fan on the freezer and fridge were not cooling very well we turned the fan off and both the fridge and freezer were working better
So this is a fan in outside compartment?????
It is manually controlled by On/OFF switch VS thermostat???
What is ambient (outside) air temp??
How long has fridge been turned ON?
cleojayco
Old-Biscuit
IF you are asking about a fan used to circulate air inside the food section.....they should run when door is closed
IF you are asking about a fan used to help with air flow (draft) in the outside compartment.....they typically are t-stat controlled.
Some t-stats turn fan on/off based on condenser fin temps (very top cooling fins). They turn fan on at 130*F fin temp and Off at 115*F fin temp.
Some t-stats turn fan on based on ambient air temp.....outside air temps above 85*F fan on.
Which 'fan' and what do you mean by your statement ".....when it's running it does not get cold"
