manual refeer lighting problems on lp
epbigfoot
Have a 185RB Jayco. Had refer chimney cleaned last fall, lit good, Now while holding in gas button and clicking igniter, the gauge on front moves over to the green but no further. Let go of gas buuton and it returns to original position. Yes am getting gas to burner on stove, two different tanks used, refer doets same thing. Please help.thankuou in advance.
โš Did you see the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
3 REPLIES 3
dougrainer
How LONG are you holding the button in when the green indicator is showing. I have found, that you may have to hold it up to a minute. If so, then the Nut on the Thermocoupler is NOT tight. Usually, just a 1/4 turn on the nut will restore the millivolt connection. You do have to partially pull the refer to do this. Doug
The_Owl
Yep if itโ€™s lighting but not staying lit then the thermocouple probably needs replacing.
rrupert
That sounds like the thermocouple is bad.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
