refer stopped working on gas
jk31668
dometic refer has always worked great on gas or elect. last trip it wont work on gas but fine on elect. gas tank is full and range and water heater work fine on gas. where do i look?
7 REPLIES 7
mfinnerty
Sometimes the slots on the orifice deteriorate and the flame doesn't hit the sensor correctly. Have had to replace mine twice.
Mike & Linda Finnerty with Finn & Rosco (Golden mix brothers)
kellem
Had it happen twice over the years and both times it turned out to be a paper wasp built a nest in the orifice.....had to dig it out with coat hanger.
Sjm9911
Yup , clean the burner, and the propane intake. Also check the flue for wasps nests etc.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
midnightsadie
take burner out and clean watch u tubes for how to. call a rv tech theres mobil tech service way cheaper than a dealer.
Ava
Look at the burner and see if there is a little pile of tiny metal bits pulled under the burner. They are rusty filings coming from the boiler tube above. If so, some of them can plug the burner up. Vacuum or blow out the burner tube and try to light again. This something I do a couple times a year when mine quits.
MitchF150
Do you hear the spark thing trying to light? It'll sound like "click, click, click" until it turns off if it does not light within about 30 seconds and then the "check" light should come on, on the fridge panel.
Do you smell gas in the outside refer vent area when it does this and does not light?
Is the gas tube plugged where it enters the flame area?
Good luck! Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
2oldman
youtube has some good help on this
