Refer Works on Propane, Not AC
Grodyman
Any reason an rv refer will work wonderfully on propane, but not work on AC power? I have this problem in both the 2012 5th wheel and the 2011 Lance. Neither work on AC.
Gman
2017 F150 CC/5.5' 4x4 3.5 Ecoboost/3.55
2018 Passport Ultra-Lite 153ML
4 REPLIES 4
southernkilowat
Working on propane and not AC tells me that you have not lost the charge and the cooling circuit still works fine. First you have to verify that you have 120 at the frige, open the back panel and check where its plugged up. If you have 120 there, move on to the back of the unit. There is a black plastic cover there, remove it and check all the fuses under it. If you have 120, and good fuses, my next bet would be the electric heating elements located at the bottom of the stack. Should have two yellow wires coming out; follow them back to the control board and ohm them out to check for resistance. If its none of the above, take it to an expert.
Good luck
Dave
TucsonJim
Just guessing, but is is possible it's on a GFI breaker or plug that has activated?
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
wolfe10
Is outlet hot? Fuse on PC board good? heating element good? That is about it!
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
donn0128
What brand refer? My Dometic works just fine both ways. Maybe you need to ensure you actually have 120 volts at the refer plug.
