โJun-27-2016 06:09 PM
โJun-28-2016 05:31 PM
โJun-28-2016 03:18 PM
โJun-28-2016 02:56 PM
โJun-28-2016 02:26 PM
โJun-28-2016 01:27 PM
TomG2 wrote:pianotuna wrote:
Well if you don't want to "pay the park" you could always add a solar system. It is the nearest thing to a free lunch that one can find.
The investment in solar large enough to run my air conditioner twenty hours a day would be pretty large. More than I want to make.
โJun-28-2016 01:07 PM
โJun-28-2016 12:39 PM
โJun-28-2016 12:14 PM
โJun-28-2016 12:11 PM
pianotuna wrote:
Hi Tom,
It is nearly impossible to use 10 KWH for just the fridge. They commonly draw 325 watts. That would 7.8 KWH per day if it never cycled. Are you running the seal heater? If so turn it off.
โJun-28-2016 11:58 AM
MEXICOWANDERER wrote:
4.4 lbs per gallon. A 20 pound pot is filled to 85. Better refactor your calculations. Check OPD valve data. Four gallons and small change for fourteen dollars. I've never encountered an RV refrigerator that cooled as good on electricity any electricity than it did on LPG. I even tried tweaking my regulator to 13" water column which helped a little on gas. Electricity cooled new Nor-cools to the low 60's while gas minimums were high forties, low fifties.
Drilling out burner orifices was a waste of time. Overheated the burner chamber.
โJun-28-2016 09:36 AM
โJun-28-2016 09:18 AM
dougrainer wrote:
What IS the cost of LP that they deliver? They do NOT deliver a cheaper price LP than if you purchase at their store location. Now, if you have a motorhome, then having them fill at your site is going to be cheaper than going to them. Doug
โJun-28-2016 09:13 AM
โJun-28-2016 08:48 AM
