FW tank fills when fw hooked up via hose.
D_E_Bishop
Our 2002 Winnie 32V water tank fills when hooked to shore water. All valves are in correct positions. I am looking for the exact location of check valve, if there is one. I looked at on-line PDF but not labeled clearly. I did not se any CV just V designations.
I know it could be a leaky valve and they are all plastic. Both shower faucets are shut securely. Any ideas.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
6 REPLIES 6
jjjandrbaker
dave17352 wrote:
Now did it solve it instantly or after a while? ๐Ÿ™‚
You got me,dude. My kind of humor!
Jim Baker
San Antonio, TX
travel blog and photos
Old-Biscuit
Water pump has an 'internal check valve' ---- a diaphragm ---- that seals off to stop backflow thru pump.
Also if you have a 'Fill' valve it can be leaking thru
Disconnect pump suction line and see if water runs out (back thru pump) when using city water.
If it does......install a in line check valve (Shurflo has them) in pump suction line ($10-15) Problem solved.
If no water ...then fill valve is leaking thru.
dave17352
jjjandrbaker wrote:
RWjSIM2003 wrote:
you can also try running the pump for a while and sometimes that will free up the Check Valve in your water pump and stop the problem.
X2 I had the same problem once, and running the pump for a while solved it instantly.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
jjjandrbaker
Jim Baker
San Antonio, TX
RWjSIM2003
Hoosier_Cruiser
Look for a check valve in the 12 volt water pump. If you can disassemble, maybe just dirt in the valve. Replacement pump heads can be found on ebay if needed.
Hoosier Cruiser
