removing rv decals
snowpeke
I would like to know how to remove decals of my 2002 Sprinter 5th wheel. They are peeling off and would look better with them gone!
2002 Chevy DuraMax
2014 jayco eagle
Two Pekingese dogs
10 REPLIES 10
Dtank
Try an archives search - Decal (and vinyl) removal -and "ghost" cleanup - has been on the TT, MH, 5th - forums a lot over the years.
westend
I would use something like this Vinyl remover or at least experiment with it before getting out the scrapers and heat gun.
'03 F-250 4x4 CC
FrankShore
+1 with ScottG
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
ScottG
Use a heat gun and once you get an edge lifted, keep the heat about 8~10" away and just keep pulling the decal off. If you pull it directly back onto itself then it wont leave much, if any, adhesive behind.
Keep in mind that it will leave a ghost image of the decal behind. Whether that looks better than the failing graphic is hard to say.
snowpeke
Watched the video, looks like a week project!
2002 Chevy DuraMax
2014 jayco eagle
Two Pekingese dogs
BB_TX
I used a heat gun, plastic scraper, and 3M adhesive remover.
Grandpere
Heat gun, PLASTIC razor blades, and lots of elbow grease. Then use acetone to remove the glue residue. The eraser wheels are useful, but not the total answer. They work best on narrow stripping. Here is a link to a useful you tube video put out by Laura & Sasha RV Decal Removal
Berniece & Russell Johnson
Lil'Bit, a Netherland Dwarf Rabbit
1987 Southwind
1995 Ford F150 Supercab
Life in the fast lane? No thanks, we will stop and smell the flowers at every opportuity
revump
I took mine to Alfateers. They do it on a regular basis.
Bob
donn0128
Heat gun and razor blades, also 3M makes a tool that mounts on a drill that is suppose to work well.
