3000 is a Big inverter
just what are you running from this during the day AND night
also keep i mine, that a few months ago was Mid Summer
and even on sunny days you are now getting less Solar Charge per day
so IF you have too much day use power the batteries are Not being fully recharged
and a Heavy enough load can cause a voltage Drop on the circuit
where is the inverter connected ? it should be connected directly to the batteries
also the output from the solar charge controller should be connected directly to the batteries
do your 12v lights work at night, water pump, heater etc..
I can explain it to you.
1997 F53 Bounder 36s
