Replacing a A-frame Jack, need to enlarge 2" hole to 2-1/4"
Trailmanor13
Replacing my A-frame jack and the new one has the outside tube of
2-1/4" where my old one was 2". the 2nd (bottom) hole in the a frame is 2" and I need to enlarge it to 2-1/4"
This is on a Trailmanor 3326 travel trailer.
Is there any easy way to make that hole 1/4 inch larger?
Jack I am trying to install
https://www.curtmfg.com/part/28204
Thanks
24 REPLIES 24
jjrbus
WhatCummins12V98 said. Piece of pie! The circle
you drill out of your guide piece is called a rountuit. Now you have a rountuit for all those things you have been putting off till you get a rountuit!
Cummins12V98
Drill a 2-1/4" hole in plywood or steel and clamp over existing hole centering the template over existing hole. Drill away, ez-p-ze.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Trailmanor13
I was thinking of using my sawzall with a diablo metal blade and cutting 8 cuts about 1/4 of a inch in and using a vicegrip to bend them out some and then tapping the jack into the hole. The top hole in the A frame is big enough, just the bottom hole is too small. The metal is less than 1/8"
agesilaus
K Charles wrote:
2 1/4 hole saw is about $15 at any hardware store
The original hole will still have to be enlarged since the new jack will pass thru that. And I find enlarging an existing hole, with a hole saw, to be a tough job tho I'm sure there are tricks I don't know.
A good 2 1/4 in bimetallic saw blade runs about $18 plus a mandrel at $15 if you don't have one. A grinding stone is probably less than $5
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
okhmbldr
Use a grinder bit in your drill....just keep going round and round until the hole is the size you need.
K_Charles
TomG2
Exchange jack for one with a 2" tube.
agesilaus
Bumpyroad wrote:
weld a plate over the hole and use the right bit.
bumpy
A 2 1/4 inch metal bit?! Does he use a 3/8 or 1/2 inch drill motor? (Sarcasm on). Grinding seems much more practical for the average DIY selfer. Someone who does not own a metal working shop anyway.
Superbumper
Bumpyroad
bumpy
jdc1
Grind away. 1/8" all the way around. That does sound unusual. They is a standard.
