โFeb-19-2020 05:15 PM
โFeb-25-2020 08:28 PM
โFeb-23-2020 02:22 PM
โFeb-23-2020 04:26 AM
โFeb-20-2020 05:23 PM
Ron3rd wrote:I understand if you cut the plug off the warranty is void. At least make a pigtail if you need to hardwire.
Robert, Nice work and nice photos too. I'm going to be replacing my WFCO converter eventually. I like your tip to make it a plug in unit.
โFeb-20-2020 11:50 AM
โFeb-20-2020 11:13 AM
โFeb-20-2020 10:31 AM
โFeb-20-2020 07:55 AM
โFeb-20-2020 07:27 AM
โFeb-20-2020 06:38 AM
โFeb-19-2020 07:17 PM
Bud
USAF Retired
Pace Arrow
โFeb-19-2020 06:13 PM
GetGoing wrote:
When plugged into shore power, after a few hours the coach batteries were drained. Lots of YouTube articles learning about RV electric I am very confident that the converter is not working. This was installed in a 2007 Coachman Mirada and seems the same model is still available. Amazon posting said it was a 3 stage converter which I assume was referring to the stages of battery charging. I would value input from others as I research from other internet sources.
โFeb-19-2020 06:00 PM
โFeb-19-2020 05:42 PM
time2roll wrote:
Do not replace with a WFCO. The stated 3 stage charging frequently does not work.
Progressive Dynamics, IOTA, Power Max are all good.
For camping plugged in I recommend 35 amp PowerMax
If you are off-grid a lot using a generator etc something different might be better.
