replacing decals should I clean/ redmax before or after
monicarick01
I removed all my arctic fox decals and I need a new finish on the faded gel coat. I have read hundreds of post about the steps involved with cleaning and recoating but none of them say whether to replace the decals before I use a red max type product or after the red max type product. My concern is if the decals will stick to a freshly sealed surface I know it will be a lot easier to clean and "wax" the tc without the decals on.
Thank you for the input.
5 REPLIES 5
monicarick01
I just received an email from Northwood the makers of Arctic fox. They said that you should clean the rig than put on the decals and then put on the sealant/wax.
Thanks for all your input
Mark_Heisler
Decals need to be installed on clean,dry,oilfree and waxfree surface
if not done right you will be doing them again.
once the decals are on and dry them put your red max on
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
USARMYCW
Decals need to be installed on as bare a surface as possible.
monicarick01
I am sorry what does that mean?
Reddog1
Moved from the TC Forum.
Wayne
Moderator
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
