Roof spot light and airhorn question
JimInMich
Just purchased a 1987 GBM ( class A ). I noticed 2 items on the roof up front. #1, looks like a remote controlled spot light. I dont see where it could be controlled inside the cab. Any idea's on what to look for?
Also, I see what looks like a nice set of air horns. I do have a rocker switch on the dash that reads " Horn ", but nothing. Any idea's?
Current: 1987 Georgie Boy Encounter 34',John Deere chassis,460c.i./C6.
SOLD-2012 Cougar XLite 27RLS
SOLD-2008 Aerolite 24FB
SOLD-2004 Shadow Cruiser Fun Finder 189FBR
Just the Wife and I.
11 REPLIES 11
DrewE
There's always the possibility that it might be an electric trumpet horn rather than an air horn, particularly if you can't see any sign of an air hose or tank or associated appurtenances.
mchero
The air horn has a solenoid between it and the air source. Going price for solenoid around $40. More for the Hadley branded solenoids.
Brother-in-laws motorhome would pop a fuse when he hit the air horn. Appears the solenoid is shorted.
Check ALL fuses and dont forget to dump the air pressure B4 tearing into any air lines.
Keep us posted on your progress.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
JimInMich
UPDATE: I found the spot light joystick and power switch! It was installed in front of the steering column, so when sitting in the drivers seat, you really don't notice it. Works wonderfully! Left/right/up/down and bright as heck!
Still trying to figure out the air horn......
JimInMich
As for the spot light, I can not find any joy stick controller, anywhere. When I switch the horn rocker on the dash, I still get the automotive horn when I press the steering wheel horn button. I called previous owner, and he had no idea. He owned it for 13 years and never tried to use either. I guess next step would be to figure out how to drop the overhead dash and look around. Also will try to find an air tank hiding someplace.
MEXICOWANDERER
I have a "Klaxion" double-trumpet above my seat. It is aimed sideways. If an oncoming big rig fails to extinguish super headlights and 8 auxiliaries they get a rude surprise. "Shave And A Haircut" in Mexico is extremely offensive.
Ozlander
Air horn needs air pressure to operate.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
wa8yxm
On the dash look for a 'Joystick' or Joy pad for the light, It will have an on/off and either 4 buttons arranged in a square or a "joy stick" type thing.
For the Air Horn turn on toggle press horn ring/button on wheel.
noplace2
A post that will likely be deleted, but, PLEASE don't use either when in proximity to other sentient beings who can see/hear you! Thanks
โ€˜Love is whatโ€™s in the room with you if you stop opening presents and listen.โ€™ - Elain - age 8
MEXICOWANDERER
Remote controlled spotlights on RV did not seem to last a long time. When I priced a marine model for the Kelley II, I about fell over backward. Apparently the RV version isn't quite as pricey or durable.
Trackrig
Our spotlight uses a remote control to turn it on / off, rotate and tilt it.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Diesel_Camper
Not sure about the light, but in the trucks I drive the horn rocker switch switches between a regular car horn or the air horn. Whichever one is selected is what you get when you hit the steering wheel horn button.
