I have two of trailers parked here at home both plugged into 120VAC receptacles in my garage that are on separate circuit breakers. My receptacles are 15AMP version but the breakers feeding them is a 20AMP circuit breaker in the mains box.
I use 50-foot 10 GAUGE (10-3) extension cords running out to the middle of the yard where the 30AMP shore power cables from the trailer get to. I have used a 12 gauge size extension cord without any issues but would not recommend going any smaller than 12-gauge.
I use a RV30A-15A long dogbone style ADAPTER (WALMART) and would not recommend using any of the small round type adapters as they have always got hot on me over time. The long dogbone adapters run cool to touch.
I would not use any of these small round type adapters
Using these small adapter will result in your shor power looking this over time and will need to be replaced and could be the source of voltage drop in the trailer when being used.
Prior to hooking up o the garage receptacles or to the ends of the long extension cord laying in the yard I use one of the circuit testers (LOWES) to insure I have proper test lights showing NORMAL before using the 120VAC source.
Inside the trailer i use one of these RV 120VAC plug-in VOLTMETERS in a location where I can get a quick glance before turning on my air conditioner.
This is how I insure all is ok to use the 120VAC power from my garage 20AMP service prior to being used. Been doing this since 2009 without any problems and run just about everything inside the trailers including the air conditioner and high wattage microwave. The only thing to watch for is not to have two many high wattage items on the same time otherwise it will trip your garage breaker.
I feel my connections on a regular basis to make sure none of them are getting hot on me.
My garage 120VAC operation
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
