โMar-16-2017 05:54 PM
โMar-20-2017 06:30 PM
DieselBurps wrote:
Back to my genny issues. I have no doubt I can run my 11000 BTU ac with something like the micro air easy start, the problem I have with it, is the genny is still going to be close to maxed out RPM and noise wise with the AC on.
โMar-20-2017 05:30 PM
DieselBurps wrote:yes.... that genny runs at 1600 .....it will rev up.... you can try one and see..
To my ears, the 2000 watt Hondas seem quieter than my 2000 Yamaha, it's more of a lower sound.
โMar-20-2017 04:37 PM
โMar-20-2017 04:46 AM
rockwind1 wrote:
i run my 13,500 btu dometic on two hondas in parallel, no eco for starting. but i am interested in that soft start kit but **** it's expensive. anyone had any experience with them. is it made in usa?
RSD559 wrote:
The one in the ads is. You can get a generic kit for $30 or $40 online. Here's an example. This one is for Dometic units.
Dometic Hard Start Kit
You basically have to pull the cover off the AC unit and follow the directions on where to plug the leads in.e
โMar-20-2017 01:28 AM
pnichols wrote:Correct, but...... If it is hot enough to need the AC, you will be inside. You cannot hear the generators over the sound of the AC.... Not sure just what the decibal reading is, but the AC makes the most noise.
Reading some of the above comments, I'm wondering if some aren't confusing "running in Eco mode" with "running at low RPM's"?
Aren't a couple of EU2000i generators supplying 1400-1500 watts to a 13.5K A/C (whenever it's compressor is cycled ON) still going to be about half way into each of their RPM ranges? If so, then you're beyond that great 53dB true idling low speed sound that the EU2000i's are famous for.
โMar-19-2017 07:11 PM
pnichols wrote:Yes, that's about right. No, they are not as quiet as idle, but much quieter than one.
Aren't a couple of EU2000i generators supplying 1400-1500 watts to a 13.5K A/C (whenever its compressor is cycled ON) still going to be about half way into each of their RPM ranges? If so, then you're beyond that great 53dB true idling low speed sound that the EU2000i's are famous for.
โMar-18-2017 07:15 PM
โMar-18-2017 10:28 AM
โMar-18-2017 09:27 AM
โMar-18-2017 02:44 AM
โMar-17-2017 09:56 AM
โMar-17-2017 09:08 AM
โMar-17-2017 08:35 AM
dfb wrote:DieselBurps wrote:yes....since you can run on one, the other will produce enough in eco mode..
Curious if this is possible or anyone has done this. Currently I can run my Coleman mach air conditioning unit in my truck camper off just one yamaha 2000 watt generator but it's not happy about it and from the sound I can tell it's maxed out. I am wondering if I were to run two 2000 watt generators in parallel could I do it with the eco throttle on? It seems like this would be possible since both generators are putting out 26 amps and given the fact I am able to start it and run the ac with just one.
โMar-17-2017 07:06 AM
dfb wrote:
Twin hondas have a larger engine than the twin yamahas.
โMar-17-2017 06:51 AM
