โJun-30-2021 04:25 PM
โJul-01-2021 03:56 AM
โJun-30-2021 10:38 PM
โJun-30-2021 10:19 PM
Grit dog wrote:
Its not leaking on the intake side, it's leaking on the air filter side, which likely isn't "water tight" anyways. The problem isn't the leaking there. But it's likely what wobachop said. Float is sticking. Also means it's inhaling that gas and likely flooded.
Did you remove the sparkplug to check?
And yes if enough gas made it through, some likely washed down into the crankcase. Id' check/change the oil once you get er running.
See if it's flooded first.
โJun-30-2021 06:56 PM
wopachop wrote:
Its leaking on the intake side. I get the feeling your float needle valve is not sealing.
Which unfortunately means gasoline might have made it into your engine oil. Smell the dipstick.
Can you pull the carb pretty quickly? Get the carb off the motor and hit prime. You should not have any gasoline dripping everywhere. Will need to clean or replace the needle valve and hopefully the kit also contain the needle valve seat.
โJun-30-2021 06:37 PM
โJun-30-2021 05:59 PM
โJun-30-2021 05:11 PM
