RVing Drives Me Nuts ---- Electrical Issue
Hoppypoppy
Brought my 2002 Cardinal home from storage last Fri. Checked lights - everything fine. 5er sat in front of my home til this morning. (Tues) Hooked it up, ready to go, no tail, brake or turn signal lights on right side only. Left side fine. First thought was a ground issue. Now the dumb question.....is the only ground on these rigs the ground included in the power plug to tow vehicle? Any other suggestions? Thanks all.
33 REPLIES 33
jvann1
My problem turned out to be bad connections between the 7pin plug wiring and a fuse block hidden between pigtail and RV wiring. Sometimes would work, sometimes would not. 7-pin plug checked fine, worth a check.
Ford F250
V-10 torqshift, tow command
Komfort trlr
"April" the attack cat!
TucsonJim
Here's a wiring diagram of the 7-way connector. Since it's affecting stop lights, right turn and tail lights, it's more than one pin (Pins 3&6).
Since you have tail lights on the left side, and not the right side, I wouldn't believe the issue is with your 7-way because the tail lights for both sides are on pin 3.
My suspicion is that your right side bulb is burned out or you have a bad connection between the trailer wiring and the right side light housing. I'd start by putting the left side light on the right side. If it works on the right side, you'll know it was the bulb. If it doesn't work, pull the right side lamp fixture and check for connection issues.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
geotex1
Provided through battery circuit too. Did you try the obvious and clean your trailer connector? Only takes a little corrosion. Normally unplugging/plugging in to the TV will clean off flash corrosion, and if things works again you know some time with a fine wire brush, contact cleaner, and corrosion inhibitor is in your future. I'd start there, then if no joy move onto checking your battery connections and then trace the ground wire to find the frame attachment. If you have a multimeter or test light, you can check for continuity between one of the light sockets to trailer frame, but since it's only one side I'd gamble on being the feed to that side.
donn0128
Take another plug and using your 7 pin wiring diagram connect a jumper from battery+ to each of the other connections and start checking. That way you will know for sure whethernit is truck or trailer issue.
