satalite connections
army_guy1
Hi folks,
I've got a question - I am running cable from sat dish (traveler three) under my slide out and up into the back of my entertainment center into an A/B switch. When I went to hook up the main line from the receiver to the A/B switch, I got a spark from the cable line. Could I have shorted something or is this ok?
Rick & Jana
Full timing since Oct 2005 - retired US Army Dec 2009
2018 Arctic Fox 27-5L
2014 RAM 3500 Big Horn
4 REPLIES 4
accsys
. double post
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
accsys
Every time you use that A/B switch you are going to get a similar arc across its contacts. This will shorten its life unless you unplug the receiver before switching antennas. If you are using a SWM system, you also need to unplug the power inserter. Once you switch antennas with the A/B switch, power everything back up and all is good. I learned this the hard way!
John & Doris
Fred_n_Jo
That cable is a two way street. From the dish to the receiver it carries the television signal. From the receiver to the dish it carries power and instructions that the antenna needs.
2017 Host Rainier Truck Camper
2015 F450 Lariat 6.7L PSD CC 4x4
our places camped Map
our rig ready to roll
Valkyriebush
I don't think that's an issue? I've seen that spark when the two wires touch. Might be why my receiver (211)says make all connections before plugging in.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
