โJul-13-2020 06:00 PM
โJul-15-2020 10:56 AM
Dutch_12078 wrote:mchero wrote:
I'd get one of those devices you stick down the drain and rotate to get hair out. I was AMAZED at the amount I pulled from our shower and sink drains!
Reread the first post, he already tried that. I don't recommend those clog sticks for Hepvo's though, since the "teeth" on the stick can damage or invert the "duck" lips that seal the odors out.
โJul-15-2020 10:43 AM
โJul-15-2020 10:00 AM
โJul-15-2020 05:17 AM
โJul-14-2020 06:31 PM
dougrainer wrote:
If the water is NOT in the shower pan but you can see it below the round strainer, that is NORMAL. For either a Hepvo or P trap system. That is your Water barrier to keep gas/odors from coming back up. Doug
โJul-14-2020 05:05 PM
โJul-14-2020 05:04 PM
โJul-14-2020 05:02 PM
Fisherman wrote:
Use a toilet plunger and blast it out.
โJul-14-2020 04:23 PM
Fisherman wrote:That'll work, but go easy at first. I usually have the problem on the first shower after a long dry spell. When still in the shower I stomp hard on the drain a few times with the ball of my foot. Works every time for us. After the first time it usually works fine for the rest of the trip.
โJul-14-2020 01:04 PM
โJul-14-2020 10:14 AM
โJul-14-2020 06:02 AM
Dutch_12078 wrote:
Some RV's use a "Hepvo" or similar inline seal instead a traditional 'P' trap. The rubber "flutter valve" seal opens when there's sufficient flow through it, and it's normal to see some retained water in the drain. As the valve ages, it can get stiffer and retain more water than when new.
Hepvo Waterless Valve
โJul-14-2020 04:15 AM
โJul-13-2020 06:29 PM
