Shurflo Smart Sensor Pump
jereswain
Greetings all. I have a stumper. My Shurflo Smart Sensor water pump is giving me trouble. My water system will act like there's air in the lines (sputtering) then go immediately & completely dry. 5 minutes, 1 hour, 1 day later (there's no rhyme or reason), it will come back on, only to fail again. My electrical connections appear sound. The pump works fine when it decides to. I've detected no leaks where it's housed.
My dilemma is, "Is the pump failing?" or is something else going on? Any experienced advice, suggestions, shots-in-the-dark or psychic predictions would be most welcomed.
Many thanks.
3 REPLIES 3
Old-Biscuit
Sucking air.......
As suggested, check suction side of pump----pickup line, strainer, fittings, winterizing valve/fittings
beemerphile1
Probably sucking air. Check the line between the pump and the tank including the winterization valve if you have one.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
ken_white
Many thanks.
Probably the pump's pressure switch diaphragm or switch itself is faulty or there might be a filter with dirt clogging it causing these symptoms too.
2014 RAM C&C 3500, 4x4, Club Cab, Hauler Bed, DRW, Aisin, 3.73's, etc...
2013 DRV Tradition 360 RSS
LED Lighting
570W of ET Solar Panels
MorningStar MPPT 45
Wagan 1000W Elite Pro Inverter
Duracell EGC2 Batteries with 460 A-H Capacity
