โJul-29-2022 12:42 AM
โAug-13-2022 08:42 AM
Rick Jay wrote:
Hi Chris,
Definitely check it with a magnet.
Here's the link to Pot Metal from Wikipedia. Basically it's an alloy of various metals which have a low melting point (cheaper to melt at lower temp, and not much strenght) which allows manufacturers to make an inexpensive casting of an object. It usually has little, if any, iron in the mix as that would raise the melting point, which requires more energy to melt, and thus more expensive to produce. The driving force behind pot metal is CHEAP! ๐
In the link above, an important line is this: "Depending on the exact metals "thrown into the pot," pot metal can become unstable over time, as it has a tendency to bend, distort, crack, shatter, and pit with age. The low boiling point of zinc and fast cooling of newly cast parts often trap air bubbles within the cast part, weakening it." So this kind of makes it a "ticking time-bomb", so to speak.
The replacement parts, and I assume the new Tri-Mark locks, use steel for the part which provides considerably more strength and is more ductile and less brittle, so it's very unlikely to crack. And steel, with its high iron content, is magnetic. Hence why a magnet test will easily show which type of metal yours if made from.
Hope this helps.
~Rick
โAug-13-2022 08:11 AM
โAug-13-2022 07:40 AM
โAug-12-2022 08:40 PM
SJ-Chris wrote:Rick Jay wrote:
SJ-Chris,
I applaud you for your solution to prevent the slider bolt from extending all the way. I could tell from your pics that yours didn't break. However, it WILL break. And this guy named Murphy will tell you that when it does, it will be at the worst possible time. ๐ You've already closed the door (probably several times) with the slider bolt over-extended. That put lateral stress on that part, and might have already weakened it. That's the problem, when it breaks, there IS no warning. The door does NOT open and you're trapped...either inside or outside.
The first time this happened to our rig, I was surprised how many others had the EXACT same problem. And like I said, we pretty much babied the closing of the door...I detest door slammers! LOL Anyway, I believe, there were some folks who sent documentation to the NHTSA to see if Tri-Mark could be forced to fix this as this could conceivable be a life-threatening failure if the lock broke and there was a fire inside the RV. Perhaps a "perfect storm" of problems, but not outside the realm of possibility. We have a driver's door on our Class A, but if the fire is at the front of the rig, that door would be useless. If the main entrance door didn't open, then wifey and I have to try to squeeze our "not so skinny" butts out the emergency window in the bedroom with the requisite "fall" to the ground. LOL
Ok, just my line of thinking, but what I paid for that upgraded steel bolt and the peace of mind it provides, I felt it is well worth it. I didn't want to take any chances, and when the kit mentioned above became available, I quickly ordered it and installed it.
I'd recommend that you order it. The frustration you save will be your own! ๐
Safe travels,
~Rick
Thanks for the info/suggestion! I'm not opposed to spending money on these things as I do like everything (every light bulb in fact) to be working correctly.
It seems there is a big difference between the "pot metal" vs the "actual metal" bolts and their durability. The "pot metal" bolts are the ones that break. I haven't searched it, but I haven't heard anyone state that their "actual metal" bolt broke yet. I've also heard that the pot metal bolt is not magnetic (...side note: I find this strange....what IS pot metal???). I will likely put a magnet to mine to see if it is real metal or pot metal. If it is pot metal, I will be much more inclined to replace it as you suggest. If it is actual metal, I think I'm comfortable keeping this bolt in there. I'll let you know what my test reveals....
Happy camping!
Chris
โAug-12-2022 04:16 PM
Rick Jay wrote:
SJ-Chris,
Safe travels,
~Rick
โAug-12-2022 03:57 PM
โAug-12-2022 02:31 PM
โAug-11-2022 07:37 AM
IAMICHABOD wrote:
I book marked a E Bay seller a while back that sold a repair kit that may have been mentioned earlier.
Trimark Repair Kit
โAug-10-2022 10:04 PM
โAug-10-2022 07:16 PM
SJ-Chris wrote:ScottG wrote:
It's a $25 item - just replace it.
Which item is $25?
A new complete door latch from TriMark is ~$150+. Are you suggesting that just a part of this latch needs to be replaced? If so, I wasn't thinking that was an option but would be good. Please elaborate. Thanks
โAug-10-2022 06:56 PM
SJ-Chris wrote:
Someone pointed me to this video which shows someone repairing a TriMark latch unit. I think it is just what I was looking for and I'm putting it here in case someone else is wondering about the interior of this latch.
https://www.youtube.com/watch?v=Epq8MrrRF7c
About 1 minute into the video, it shows the little white plastic piece and where it goes. That is the main thing I was trying to figure out as I believe it is what is supposed to keep the springy latch from extending too far (and thus making it so the door won't close without assistance). I'm going to check it out on my latch later today to see if I can get that piece to fit in the right place. I'll report back...
-Chris
โAug-10-2022 04:10 PM
โAug-10-2022 12:53 PM
โAug-09-2022 07:25 PM
