โMay-25-2018 09:27 PM
โMay-28-2018 02:06 PM
fpresto wrote:wolfe10 wrote:
Many of us interpret this as "hold until you hear the pump start to load up". Don't see anything positive by pressurizing past that point.
Well Bert I don't know who many of us are so all I can do is what HWH says. The following is right out of the HWH 725 Operator's Manual : To extend the room, press and hold the ROOM CONTROL in the "EXTEND" position until the room is fully extended or stops moving. Continue to hold the control to "EXTEND" three or four seconds. This assures full pressurization of the cylinders. IMPORTANT: Do not hold the extend switch more than 10 seconds.
It says the same under the retract section.
I do know that if the cylinders are not fully pressurized you can get creep of the slides.
โMay-28-2018 01:51 PM
โMay-27-2018 08:45 PM
โMay-27-2018 08:15 AM
fpresto wrote:
A simple trick that may help and save some time and money: HWH on their web site says to hold the extend or retract button for at least 3 seconds and no more than 10 seconds after the slide stops. That is to make sure that the lines are charged. If they are not charged the slide may creep.
โMay-26-2018 04:01 PM
โMay-26-2018 03:30 PM
NHIrish wrote:
Could also be a bypass leak in a piston....in other words, no exterior leak but the pressure leaks down internally.
The problem is figuring out the leak is...check with the system manufacturer or rv manufacturer for troubleshooting recommendations.
I found that many rv mechanics have no clue about hydraulics, so find a good independent!
โMay-26-2018 02:47 PM
โMay-26-2018 07:17 AM
โMay-26-2018 02:00 AM
โMay-25-2018 10:17 PM
โMay-25-2018 09:54 PM
โMay-25-2018 09:51 PM
