โDec-10-2020 04:39 PM
โDec-15-2020 10:33 AM
โDec-15-2020 07:31 AM
โDec-15-2020 07:02 AM
โDec-13-2020 08:47 PM
โDec-13-2020 09:45 AM
โDec-13-2020 09:37 AM
BFL13 wrote:S Davis wrote:MEXICOWANDERER wrote:
I am satisfied with my Samlex 300 PSW. Anker makes excellent USB chargers for cigarette light user.
True to form Orientals make true garbage power connectors. A Blue Seas marine plug and socket fed by a dedicated TEN AWG cable and 30-amp fuse I'd the ideal power feeder.
Just make sure you get pin terminals if you go bigger than 8 awg, I found this out yesterday. I had to install the inverter about 6โ from my cab connections under the center console and they recommend 6 awg, guess what 6 awg will not fit.
Just use 6" of #8 as pigtails and then go #6 from there. Various ways to joint the #8 and #6 ends.
โDec-13-2020 09:20 AM
โDec-13-2020 09:13 AM
RJsfishin wrote:My experience has been the exact opposite.
If its cheap, that's what it is. I have tried 3 inexpensive psw inverters, and all 3 were junk, had herringbone across the tv screen, and or a hum in the audio. and high draw at idle. Went back to msw and never looked back and never a problem. I don't know what all the hype is about psw.
โDec-13-2020 09:10 AM
โDec-13-2020 08:22 AM
โDec-13-2020 07:04 AM
RJsfishin wrote:Did you buy a cheap msw?
โDec-12-2020 04:03 PM
โDec-12-2020 12:08 PM
โDec-12-2020 09:30 AM
