โSep-05-2016 11:43 AM
โSep-24-2016 06:27 AM
lane hog wrote:
..I also installed a $5 fuel shutoff about 3" from the carb inlet, so that hopefully it never sits wet again. Shut down the gennie after about 60 seconds of closing the valve....
โSep-24-2016 05:01 AM
โSep-23-2016 07:11 PM
j-d wrote:j-d, I just picked my MH up from the shop today. Generator would not start. The mechanic said he put a new carb on it. So far it is running fine. It was costly, but it is 8 years old and this is first problem I have had with it.
You ended up on the same path I took with an ONAN carb. I made several cleaning attempts and couldn't clear it up. Took it to a shop. You paid about half what I did, but I was as grateful as you are, and it took an ultrasonic cleaner to get it done. They called it a "rebuild" but that was years ago, when there were still some kits available. I could tell right away that the carb was better, but there was still a slight surge. Several steps down in the surge troubleshooting was "replace governor spring" and I decided to jump to that for $3 without all the other steps first. It did the trick.
GLAD you're enjoying a nice-running genny!
โSep-23-2016 05:51 PM
โSep-23-2016 03:21 PM
โSep-23-2016 02:49 PM
โSep-10-2016 08:47 PM
lane hog wrote:
Guys, I asked about Acetone. Not carb cleaner or Seafoam... ๐
โSep-10-2016 09:02 AM
โSep-09-2016 09:49 PM
โSep-09-2016 09:48 PM
John&Joey wrote:
MW, you are a plethora of sage advice ;).
โSep-09-2016 08:43 PM
โSep-09-2016 04:31 PM
โSep-09-2016 02:13 PM
dougrainer wrote:
SEA Foam does not always get all 16 open and clear.
โSep-09-2016 02:02 PM
