Sodium Ion battery
pianotuna
Nomad III
Nomad III
Hi all,
Sodium ion batteries are starting to appear.
They can be used from -70 to 100 C (-94 to 212 f) https://pubmed.ncbi.nlm.nih.gov/35044037/
Sodium is dirt cheap compared to Li.
Right now the sodium ions are pricey...
https://pubs.acs.org/doi/10.1021/acsenergylett.0c02181#
Regards, Don
7 REPLIES 7
pianotuna
Nomad III
Nomad III
Ed_Gee wrote:
Read and understand the entire paper. These batteries are far from commercial use so far. Basic conclusion by author .. more research and development needed if this chemistry is to compete with Lithium based batteries.
https://en.imsilkroad.com/p/322980.html?gclid=CjwKCAjw9e6SBhB2EiwA5myr9u0YGYKA5XNJxVZuLokQTuoiYupvmI...
2023 is just around the corner!
Regards, Don
Lwiddis
If anything will save us it will be R&D.
StirCrazy
Navigator
Navigator
they have been in development since 2009 ish, maybe before then nd are being used in Japan and other places but have some issues that make them pretty much un usable for us.
https://www.sciencedirect.com/topics/engineering/sodium-ion-battery
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Ed_Gee
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Boon_Docker
3 tons wrote:
Interesting!โ€ฆWould be a good thing - no doubt thereโ€™s waaaay more salt on the earth than Lithium!!โ€ฆMakes me wonder if it has similar characteristics as SiO2?.
FWIW (on a lighter note!), when my boy was just a youngโ€™ien we once made a battery out of a Lemon, a nickel and a copper pennyโ€ฆWe never evaluated it in cold weather (or for itโ€™s Peukert), but as I recall, itโ€™s voltage curve faded fairly fast, and shortly thereafter it succumbed to a Low voltage disconnect - lolโ€ฆ:)
3 tons
The LBMS kicked in and shut it down. :B
Trackrig
Thanks for the post Don, I'd like to see a good cold weather battery for -70F. I looked at your attachment, but way too complicated for my little mind. I'll wait for others to decipher it.
Bill
3_tons
3 tons
