May-20-2013 08:07 PM
May-21-2013 09:50 PM
HiTech wrote:You're not helping!! LOL!
I double dare ya 🙂
BFL13 wrote:OMG dude! LMAO! That's it, I'm sending this to my sister.HiTech wrote:Ok.--mena's sister the mermaid in her birthday suit (seen asking about solar panels--on topic!)
I double dare ya 🙂
May-21-2013 08:04 PM
May-21-2013 07:58 PM
May-21-2013 07:52 PM
May-21-2013 07:51 PM
MickD wrote:
Several have said that I should get 2 panels to total the necessary watts needed.
when I look at the specs for lower watt panels the IMP goes way down also the volts.
May-21-2013 07:48 PM
I double dare ya 🙂
May-21-2013 07:31 PM
May-21-2013 07:30 PM
mena661 wrote:BFL13 wrote:LOL! You are on a roll today buddy!
You are welcome.
MickD wrote:As long as they are nominal 12v panels they will be fine. Just make sure total Isc does not exceed controller rating.
Several have said that I should get 2 panels to total the necessary watts needed. I have no problem with that but when I look at the specs for lower watt panels the IMP goes way down also the volts. What is the effect on charging the batts? Also that means more brackets and more wire and more holes in the roof.
Mick
May-21-2013 07:25 PM
You are welcome.
May-21-2013 07:05 PM
May-21-2013 06:56 PM
May-21-2013 06:46 PM
May-21-2013 06:33 PM
May-21-2013 06:20 PM
