โJan-31-2014 09:25 AM
โFeb-04-2014 08:56 AM
chloe's ranch wrote:
Ed suggested using a second 10 guage wire between controller and batteries. Is that better than using a single heavier guage wire? Easier since one 10 guage wire is already in use? Two tens equals what guage single wire? The controller is about three feet from the batteries. Thanks again!
โFeb-04-2014 08:53 AM
โFeb-04-2014 08:04 AM
โFeb-04-2014 08:00 AM
โFeb-03-2014 10:05 PM
โFeb-03-2014 07:30 PM
Thanks again everyone for the help. Sounds like an adjustable controller might be a good idea. If I do go with option B(adding a third 120 watt panel to my current 240 watt system and using the Blue Sky 30 amp mppt controller) I have another question. Currently my two 120 watt panels are wired in parallel with 10 guage wire down a vent to the existing controller. Should I have the additional 120 watt panel run with a separate 10 guage wire down the vent and then spliced together with the current wire at the controller, and then 6 or 8 guage wire from controller to batteries?
โFeb-03-2014 08:02 AM
โFeb-03-2014 07:49 AM
โFeb-03-2014 07:42 AM
โFeb-03-2014 07:10 AM
โFeb-01-2014 09:43 AM
BFL13 wrote:
"So, then if I set my adjustable Voltage Charge controller voltage to 15.0V, does that mean my T1275's will get an actual 14.8 volts from my solar panel? "
You need a voltage spread but not necessarily 0.2v. I got that 14.8 /14.6 from an earlier version of the Iota website.
It depends. I think the PD expert on here said it was just a tiny spread needed and a lot of the spread you see is voltage drop on the wires.
Solar controllers are even more fun where you have losses in and out and who knows which voltage the adjustable setting sets? I suggest a trial and error measurement and see what makes it come out right to 14.8 Of course that 14.8 is only for 77F and it should be higher when colder and lower when temp is higher.
โFeb-01-2014 09:33 AM
NinerBikes wrote:BFL13 wrote:
AFAIK the Iota IQ4 goes to 14.8 but that's so the batteries can get to 14.6. Once the batteries reach 14.6, it stays there for 15 minutes and then drops to 14.2. Phooey on that!
I don't know any converter that will do it right in every way. That's why I still use the 13.8v Parallax 7355 as the converter for when on shore power (works great) and use separate chargers for the real battery charging stuff to proper high voltages for my 6s and Trojan 1275s.
For fast charging four 6s I use a 100amp charger that goes to 14.8 and stays there, or I can crank that voltage higher if it is cold out so it should be more like 15.1v Note that 100/440 is only a 22% charging rate and you could safely go higher to a 30% charging rate on the four 6s if you want.
Yes it is a way to get by in the fall/spring when solar is not as good as in summer, to just charge for an hour in the morning with charger and then go solar for the rest of it. Trick is to have :
- a serious charger and gen to run it
- gen hours that let you run it in the morning.
That may let you off the hook for getting more solar, so you end up with too much solar in the summer. I keep going back and forth on this, where I get too much solar for summer and sell some, then buy more for the spring and then wish I hadn't and sell that, then a sale on panels happens I can't resist so I buy more and end up with too much solar again! There is nobody who can help you if you get that affliction. ๐
โFeb-01-2014 07:59 AM
BFL13 wrote:Another reason to mount them fixed to the roof.
