โFeb-20-2014 10:00 AM
โFeb-28-2014 04:36 PM
โFeb-28-2014 04:33 PM
JiminDenver wrote:
That was before I listened to the Champ run for 2 hrs a day for a season AND before I found my cheap panels. It's not bad INSIDE the rig but pity the fool that has to put up with it outside.
โFeb-28-2014 04:04 PM
โFeb-28-2014 01:20 PM
โFeb-28-2014 11:38 AM
Snowman9000 wrote:
At rated watts, your panel makes 2.4x the watts per square inch of what the Unisolars do. I would like to know how they compare per square inch in the shade. I am doubtful the Unisolars regain the advantage on that basis.
โFeb-28-2014 11:12 AM
โFeb-28-2014 10:51 AM
crosscheck wrote:
Back then you had JiminDenver saying he wouldn't get solar and pnichols is now talking flexible solar panels.
โFeb-28-2014 10:29 AM
JiminDenver wrote:
I know that PT gets more out of his 256w in shade or cloud than I do with my 230w poly. My 230w poly gets more than my 220w mono, it can't even wake up the controller in cloud cover that the poly can pull 4-5a.
Part of a balanced system is also knowing your needs and what conditions you will be in. In my case we had 2 days of total sun, 3 days of total cloud cover and the rest were early sun and clouds by noon. So poly is the best mix of the two extremes. 16a in good sun and at least enough in the clouds to get back to float.
Remember that if you have enough power for the low light times, you will always be happy. Only have power while the sun shines and eventually you will say hello to my little friend, mister generator.
โFeb-28-2014 10:03 AM
โFeb-28-2014 09:55 AM
โFeb-28-2014 09:13 AM
โFeb-28-2014 09:09 AM
โFeb-28-2014 08:41 AM
โFeb-28-2014 08:40 AM
pnichols wrote:JiminDenver wrote:
I'd be looking for some Uni-solar rolls. Last time I checked, 65w was $100 or so.
Thanks for jogging my memory on Uni-Solar.
This Aussie link for them shows powers for their flex panels only going up to 32 watts:
http://www.unisolar.com.au/index.html
Do you have a better link for Uni-Solar ... perhaps an American distributor?
Thanks in advance.
โFeb-28-2014 08:17 AM
Thanks in advance.
