Solar panels
TBammer
I am looking to wire in 2 Renogy solar panels, but I am not going to mount them on the roof. I woul.d rather be able to set them out depending on the the sun angle I bought a kit with a controller and 2 panels. Any advise on wiring this into the existing 12 volt system and leaving plugs on the outside to plug the panels into the system? Not sure of the best location for the controller and where to splice into the existing wiring, and if I need a switch to isolate the panels when plugging them in and unplugging. The fuse and breaker panel is on the bed pedestal. Any advise would be appreciated.
2016 Chevy 2500 HD, 6.0 gasser, 4.10 dif
2019 Arctic Fox 25W
Reese Pro-Series WD Hitch
12 REPLIES 12
red31
steveh27
I use a 120 watt folding portable that works very well. I did upgrade the controller, but left it attached to the panels back. It came with 2 connecting wires, 1 with clamps and 1 with the same connectors as the other end. I bought & mounted a short 10 ga wire with the same connector to the battery. I cut it in half to wire the end to the battery & trimetric shunt.
https://www.amazon.com/gp/product/B0057ZQJ12?psc=1&redirect=true&ref_=oh_aui_detailpage_o07_s00
In my class B my battery box is under the side entrance and visible from under the side. I drilled a small hole in the side and have the connector hanging out there. A quick and easy set up.
I like being able to park in the shade and move the panel out in the sun and adjust it during the day for max solar gathering. I would not want to mount panels on the roof. It worked well for 13 days in FL in Feb.
TBammer
RJsfishin wrote:
Works either way....12v in or out.....direct to batteries.
I went down that portable road,....it wasn't good.
Where did you find the fitting?
2019 Arctic Fox 25W
2oldman
JiminDenver wrote:
T.. after 3 years of portables I was glad to have my main system mounted.
x2. I think many of us have done the portable thing and got tired of it real fast.
JiminDenver
There is something in being able to collect from first light to the last light, especially in the low sun and short hours of winter. That said after 3 years of portables I was glad to have my main system mounted. Even my portable is mounted on my tow vehicle which gets moved three times a day to keep it lined up.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
RJsfishin
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Tom_M1
I mounted two of my panels on the side of my coach. If that side is toward the sun I can leave them as is. By removing two pins on each panel I can tilt them up or remove them and set them in the sun.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
1492
Moderator
Moderator
Moved from Technology Corner
Lwiddis
Pianotuna, is right on. Portable panels, as in take them out then put them away, is a pain. OH OH! Want to go to town for lunch? Can't leave them out....put them away and upon return put them back out again.
loggenrock
Sorry, 'tuna - I'm a fan of portables! (feel like I should add "Charlie" in their someplace...). At least in the East (read: forested) I regularly need to move panels to chase photons. While travelling the alternator seems to handle recharging just fine (BTW, did you get yours repaired?). And if you use a cover while stored, well...the roof is..covered! So, portables do have their place - maybe a bit more set-up/take down, etc., but they work well in my situation! ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
KD4UPL
Controller as close to batteries as possible. Use a fuse in the positive wire. I don't know the size of your panels or controller so not sure on wire size.
You will want to make the wire between the panels and the controller as short and as big a gauge as you can. This will minimize loosing power to the resistance in the wire.
pianotuna
Nomad III
Nomad III
Wire them to a controller that is connected to the battery bank. The controller should not be in the same compartment--but should be as close to the battery bank as humanly possible.
I'm not a fan of using portable panels. Here are some reasons why.
Panels are large.
By not mounting them on the roof many hours of sunlight while trundling down the road will be lost.
Adds to the list of items to do when striking camp.
Wind and panels don't get along too well.
Recharging while the RV is in storage won't happen with portable panels.
Regards, Don
