โNov-10-2016 01:04 AM
โNov-11-2016 06:50 AM
โNov-11-2016 06:13 AM
allen8106 wrote:
For what it's worth I am installing a solar system on my 5ver at about $1,811 in cost.
4 - 130 watt panels used from Craigslist. ($65 ea., total $260)
2 - Crown 240 ah 6v batteries ($135 ea., total $270)
1 - Magnum Energy MMS1012 inverter ($737)
1 - Morningstar TS-45 Charge Controller ($143)
1 - Bogart Engineering TM-2030-RV Battery Monitor ($158)
1 - Morningstar battery temp sensor ($25)
1 - Magnum Energy inverter remote ($47)
1 - GE 60 amp disconnect w/fuses ($21)
1 - Generac 60 amp manual transfer switch ($100)
1 - 500amp shunt ($34)
1 - 200 amp DC fuse ($16)
So far I have installed the batteries and the battery monitor. I have purchased everything else and am just formulating my install plan and panel locations. I am fabricating my own panel mounts, I have developed my own wiring schematic and am doing all the install myself.
I expect to be able to run everything except the microwave and the AC without ever running a generator or being hooked up to shore power, my wife also uses a CPAP.
So why all this. To show you that a good solar system install can be done for considerably less than you think and to let you know that what you wish to run in your rig can be done within reason. You'll never run the AC on solar and you'll not likely run the microwave unless you have a really big battery bank and inverter but should be able to run everything else.
โNov-11-2016 05:31 AM
โNov-11-2016 04:38 AM
TxGregory wrote:
I have no DC outlets anywhere in my 30' thor wanderer that I can find.
โNov-10-2016 04:06 PM
TxGregory wrote:
I would need to generate around 3600 watts to power my 30 am cord/plug if I was to mimic what the power company provides using my solar panels. So my 200 or 300 watts of solar power is only going to give me around 2 or 3 amps of current
โNov-10-2016 03:13 PM
TxGregory wrote:
I am ashamed to admit that I took two semesters of electronics in college, but I do not remember anything from them! I think I now see that I would need to generate around 3600 watts to power my 30 am cord/plug if I was to mimic what the power company provides using my solar panels. So my 200 or 300 watts of solar power is only going to give me around 2 or 3 amps of current, unless I save it up in the batteries.
โNov-10-2016 02:20 PM
TxGregory wrote:
So my 200 or 300 watts of solar power is only going to give me around 2 or 3 amps of current, unless I save it up in the batteries. But panel/batteries they should power my cpap and laptops and I would only need a 800 watt inverter for that. If I want A/C I will need a generator. I can't tolerate the noise very long due to my chronic medical problems.
โNov-10-2016 12:53 PM
Sam Spade wrote:TxGregory wrote:
But I don't want to spend that kind of money if I can avoid it.
Not sure about the cost of this but I think you would be better off in the long run to get CPAP machines that run directly off 12 V and then just increase your battery capacity if needed.
Or check the wattage of your present machines and get a small inverter to power just IT from an existing 12 V outlet.
Feeding an inverter into the whole RV is probably not a good idea; too easy to overload it.
โNov-10-2016 12:34 PM
12thgenusa wrote:
First of all, welcome to the forum.
You can probably do as others have suggested and power the CPAP off 12v if you have a 12v receptacle near by and can adapt the machine to take 12v directly. However, that doesn't help you with powering laptops. Your picture doesn't come through BTW.
If powering those items is all you really want and not "everything", two 100w panels, two batteries connected in parallel and a 1000w or even a 600w PSW inverter will do nicely. Connecting the shore power cord to the inverter directly is a simple way to do it, but if you do it that way you must remember several things.
1. Make sure your converter is unplugged or breaker off or it will deplete your battery bank quickly. If your converter breaker also powers some of the outlets as mine did you will have to separate the wires and add another breaker or tripping the breaker for the converter will also turn off the outlets you probably want to use.
2. Make sure the fridge is set to gas not auto or the inverter will try to power the heat element.
3. Make sure the water heater is set to gas for the same reason.
4. Don't even try to turn on the air conditioner.
5. Remember that even though all the outlets are live, you cannot power "everything".
I have my inverter wired to "whole house" through a manual transfer switch that simultaneously interrupts the circuits for the converter, fridge, water heater and air conditioner so I don't have to remember to turn things off or back on.
I run a 2k PSW inverter that I leave on at night to power a CPAP. With the humidifier on it takes about 24Ah per night including inverter losses.
โNov-10-2016 12:24 PM
time2roll wrote:
Really need six+ batteries to properly drive a 3000 watt inverter anywhere near the max.
I think 300 watts would be fine for what you describe as your camping needs. Maybe 200 to 400 watts solar.
If you want microwave, electric coffee, toaster, hair dryer etc you are looking at 2000 watt inverter, four+ batteries and 500+ watts solar. Or just add a Honda 2000 to the above.
If you want air conditioning and the rest you need 4000 watt inverter, 3000 watts solar, and a large lithium battery. All running at 24 or 48 volts. Or add a second Honda 2000 to the above.
***Link Removed***
โNov-10-2016 11:42 AM
MEXICOWANDERER wrote:
Examine the plug in brick carefully. By law the brick must display the power voltage range admitted from the AC plug in inlet to the brick (this cord is usually disconnectable just like a laptop power brick cord)
And then the brick's info with continue on and then list the output voltage and amperage potential of the brick. Aha! This is what you are after. Write down the voltage (12 volts)? and write down the amperage (5 amps)?
Does the brick say 12 volts and 5 amps (very common)?
If yes, you can purchase a power cord that plugs into a cigarette lighter socket, then purchase a long extension (I have encountered ads for 12 feet) cigarette light plus an socket extension cords.
This is a far more practical way than using a PURE SINE WAVE inverter that wastes power converting 10 volts to 120 volts AC then back to 12 volts. The power waste going to inverter is expensive and is sort of nuts...if tour CPAP is indeed 12 volts.
But with a battery conversion the CPAP must be unplugged from the cigarette lighter before starting the engine.
โNov-10-2016 10:51 AM
TxGregory wrote:
***Link Removed***Hello, I recently purchased a 2006 Thor Wanderer 30' travel trailer. I was disappointed that I could only run my cpap machine when the trailer is plugged in. I also dislike rv parks, and I really want to spend my time elsewhere, and preferably not plugged in all the time. I am going to put two 100 W solar panels on top. They come with a mounting kit and a charge controller. I thought about just hooking them up to charge the battery, but that doesn't do much for me, because I still can't run my cpap when I am not plugged in. So I was thinking of connecting them to a second deep cycle battery (I have a place for it up front), then using the second deep cycle battery to power an inverter that I would plug into the 30 amp plug that would normally go to external power. My wife also has a cpap, and we like to spend time on our laptops. I put together a picture of what I was thinking. I need some help from someone proficient in electronics to advise me on this. I don't have a lot of money, and I am not physically able to do crawl around the insides of the trailer reconfiguring things. So I came up with this, hoping that it would not all blow up! I am unsure of the size of inverter I need. I would like to just put a 3000W one on, but they are expensive. The 1000W inverter was much cheaper. Also, I am wondering if I need three panels. I am guessing that 3 panels and a 3000W inverter, on a sunny day, would allow me to run everything just as if I was plugged into power. But I don't want to spend that kind of money if I can avoid it.
Thank you in advance,
โNov-10-2016 09:20 AM
Never in many decades heard the complaint "Bought too many panels" nor "battery bank is too large". Engine starting battery is too powerful. Points to remember well.
โNov-10-2016 08:51 AM
โNov-10-2016 08:19 AM
