โDec-13-2020 04:57 PM
โDec-14-2020 12:56 PM
โDec-14-2020 12:26 PM
โDec-14-2020 12:21 PM
โDec-14-2020 12:07 PM
BurbMan wrote:Yes and same thing on the microwave. 240v armored pigtail. Yes both that I did had stranded copper wire.time2roll wrote:No kidding? I stand corrected then. Hard to believe then that they would include an aluminum wire, it must be tinned copper.
I just put one in two years ago and the Kitchenaid electric oven most definitely came with an armored pigtail to be hardwired. No instructions to replace with a cord and plug.
โDec-14-2020 11:58 AM
โDec-14-2020 10:32 AM
12th Man Fan wrote:frankwp wrote:
Are you sure it's aluminum? That would be highly unusual. It's probably tin plated copper.
Thanks everyone for your input. I am kind of anal when it come to stuff like this.
I looked at the wire closely and it sure looks like aluminum but on the wire I found AWM style 3321 which is tin plated copper so I don't have the problem I thought I had.
The oven is at my home and it is a built in oven. There is a very heavy three conductor wire sticking out of the wall and that is how the old oven has been hooked up for 35 years so I guess going back the same way will be OK now that I know it is not aluminum.
Thanks everyone for taking the time to respond. There is a wealth of knowledge available on the site and you are willing to help. This is why I asked the question here.
The oven came wit an armored pigtail with 12 ga wire and it was not intended to be changed.
Thanks again
โDec-14-2020 08:37 AM
โDec-14-2020 08:16 AM
โDec-14-2020 07:59 AM
Hondavalk wrote:
https://www.lowes.com/pd/Alumiconn-3-Port-Al-Cu-2-Pack-Purple-Al-Cu-Wire-Connectors/4433877#:~:text=...
โDec-14-2020 07:42 AM
BurbMan wrote:Op said Oven not stove if that matters.
Electric stoves don't come with wire, they come with a terminal block that you connect your wire to.
โDec-14-2020 07:34 AM
โDec-14-2020 07:19 AM
โDec-14-2020 06:53 AM
โDec-14-2020 06:34 AM
โDec-14-2020 06:12 AM
