Suburban SW6DE Problem
Ottawa_Campers
Hi all. I am looking for some help diagnosing a problem with my suburban SW6DE water heater. It has worked fine for 12 years but now it won’t run on gas.
When I turn the switch to start the propane burner nothing happens - no light on the reset button, no ticking of the igniter, nothing. I have 12 volts at the switch, the thermostat hi limit switch is fine, and I even get 12 volts at the red wire going into the module board with the propane switch in the on position.
I don’t really know what to do from here, so any advice would be appreciated.
Darryl
2006 Grand Surveyor 240BH
2004 GMC Sierra 2500HD 4X4 CC LB 6.0litre 4.10 gears
18K Reese/Hidden Hitch Signature Series Hitch
Prodigy Brake Controller
9 REPLIES 9
Old-Biscuit
See what a little troubleshooting/testing does.....finds the problem
Ottawa_Campers
Update from the OP:
Based on the advice of Old-Biscuit, I checked for 12 volts at the brown wire on the module board. When there was no voltage there, I still suspected that there was something wrong with the module board, so I removed it and inspected it. There was obvious overheat damage to one of the circuits, so I ordered a new board on amazon.
Thanks for the help.
Ottawa Campers
Ottawa_Campers
Darryl
12V DC on RED wire AT the circuit board means DC circuit is good thru on/off switch, thru set of t-stats BUT nothing from circuit board
With DC on RED wire at circuit bd then should be DC on BROWN Wire to Gas Valve Solenoids and energizing the spark electrode with high voltage.
Check the YELLOW Wire coming out of circuit bd..GROUND and needs to be connected for circuit bd to function
Good ground.then circuit bd is Bad
Thanks old biscuit. I will check the brown and yellow wires coming out of the circuit board after work tonight.
Darryl
Old-Biscuit
Darryl
Mnflyboy
Yup...probably time for a Dinosaur Board.
SidecarFlip
12 years, nothing lasts forever. Sounds like the ignitor board is done
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
bob213
My hi limit switch looked good and even showed continuity thru the wire but it was no good.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
BFL13
Around the same age since new, I had to get a new on/off switch that goes by the red light--fixed the problem. Easy swap.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
donn0128
Check and try reset the limit switch
