surge protector
joe0508
Will a surge protector help with low voltage like a plug in voltmeter?Will they both work basically the same?
joe money
15 REPLIES 15
wa8yxm
There are surge protectors and Surge Protectors.
There is one that Camping world sells for about a hundred bucks, it has some LED's on it no digital displays, IT is a "surge supressor" really a spike suppressor it is 100% useless if you get a genuine surge (Sustained high voltage) and in fact if that happens it may remind you of a firecracker,,, I know several surge strips I had did that when I got hit with a real surge. (I should know, I was there, sounded a bit like Independence day).
A Good Energery Monitoring System, like the more expensive ones CW sells or the Progressive jobs.. This has a digital display which shows one or more of the following, Voltage, current and frequency. It may also show error codes.
These monitor the voltage, and selected other things, and will shut you off if the important things go out of range.
Voltage too high (SURGE) shut down
Voltage too low (Brownout) SHut down
Frequency too high or low (Very unlikely but) Shut down
My inverter monitors all of these and in addition the waveform, too noise (IE: MSW feed) and it switches to inverter mode. I know of no surge guard that does this though.
In addition it will check for inverse polarity, open grounds (or neutrals) and such and either shut you down or report the error, depending on how bad it is.
CA_Traveler
Personally I really like the PI hard wired version as it's not visible, no plugging it in and the remote or two remotes if you like. All parameters are visible including 10 error codes on the remote.
2014 Grand Cherokee Overland
Bob
CA_Traveler
Actually the PI units have better protection, field replaceable parts, lower price, good support and lifetime warranty. Not suggesting the TRC is a bad unit, just second best.
Bob
sljkansas
The unit you are looking at is an EMS (energy management System)and is better than a surge protector. The only thing I don't like is the 1 year warranty.
Progressive Industries has a life time warranty. I have the PI EMS 50 amp portable unit and it has saved us several time when voltage dropped from 120 to 104 they to 76 volts for about 3 hours. We were lucky, voltage droped just as we shut the lights off to goto bed. Proper power was restrored by power company 3 hour later.
Second here we had the PI unit it died, called PI, they sail send it in. unit was repaired at no charge. they said it had water damage due to a bad seal. Mow over five years and not a problem with it. Sure glad I had the lifetime warranty.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter Married.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
C_B_
Since I plugged into a brand new 50AMP pedestal that was wired wrong from the manufacturer Mothers day weekend I ordered and am installing this Surge Protector.
TRC Model#34560 50AMP Hard wired
Automatically shuts off power when the following is present:
Open neutral; Low (102V) and High (132V)Voltage.
Multi-mode surge protection
Caution lite for: Mis-wired pedestal, Reverse polarity and Elevated ground voltage.
128 second reset delay protects AC Compressor.
3850 Joules of power surge protection.
Don't want to go thru this power problem again.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
CA_Traveler
Interesting monitor that I hadn't seen before and it might be the right device for you. I doesn't display both legs of 50A power.
I camped for 20 years with no device and then bought a newer rig with a lot more electronics so I added the PI HW50C unit. One night we had 160V on a 30A plug, so glad I had the unit.
Bob
joe0508
I came across this and might save some money for some.It doesnt shut anything down automatically but it will alert you to do it manually.It seems to be alot of bang for the buck.http://www.campingworld.com/shopping/item/digital-line-monitor/24900
joe money
joe0508
Nomadac wrote:
My Surge Protector has shut off the power from the pedestal, several times when the voltage was low, protecting the AC unit.
What do you have?
joe money
CA_Traveler
Then no. A surge protector will not indicate voltage nor will it protect you from high or low voltage as in out of spec 120V +- 10%. It will be destroyed and protect against high voltage transients ie a surge.
Likewise a voltmeter will not protect you against low or high voltage unless you are watching it and can disconnect the power fast enough or essentially no protection.
A full function power protection device will detect a surge and self destruct protecting you. It will also detect high/low voltage and disconnect. Some like my Progressive Industries HW50C will display current voltage and amps and will display a error code for a prior fault like low voltage.
To protect your AC you can:
1. Watch a voltmeter all day
2. Use a full function power protector
3. Use a autoformer
4. Turn the AC off
Bob
Nomadac
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
AllegroD
A surge protector will not. A Surge Guard Power Protector and better yet a Progressives Industries Power Protector will. So it depends on what you are calling a surge protector.
A volt meter reads volts/amps/ohms/watts, depending on which one you get and can be 120 and/or 12 volt.
joe0508
WILDEBILL wrote:
Neither will help with low voltage you need an autoformer to boost low voltage.
A surge protector will help with over voltage (surge).All A voltmeter will show you the voltage.
Bill
Thanks,I know it wont help.I am trying to figure out if a surge protctor will indicate a low or high voltage to protect my air conditioner the same as a plug in voltage monitor.
joe money
WILDEBILL
Bill
2oldman
I don't think the two are similar in any way.
