System monitor issue 1994 Itasca sunrise
Stella_sunrise
Water pump doesnโ€™t work, idiot light levels donโ€™t work. Checked fuse, itโ€™s good interior lights all work so Iโ€™m assuming batteries are good to go. No power to monitor, range fan or range light. Any thoughts?
Thanks in advance.
3 REPLIES 3
1995brave
Download the Winnebago wiring diagram and it will show you the wire color, plugs, and grounds which should help you troubleshoot the problem.
MitchF150
Most 12v electric issues are ground wire related.. If all those devices are run from the same system monitor, they might be all tied into the same ground, so that's the reason those devices aren't working?
Check the ground wire to the panel and go from there. You'll need a basic multi meter, but also need to know how to use it... You could also use a power prob, but you will also need to know how to use that as well..
Good luck!
Mitch
rk911
deleted
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
