systems check board
evergladesgator
What is proper name for systems check board ? Tank levels, battery status indicator. Rocker switch took a dump. Thanks
gator
2000 F250 Super Duty 7.3 PSD.
1999 Skyline 2427 Nomad 5th wheel.Rancho 9000s, Prodigy, Me, wife & two spoiled chihuahuas. PeePee aka Penelope(6/97-7/08) & Hannah (19 now and seen the USA ). New kid Chiquita aka ChiChi.
9 REPLIES 9
evergladesgator
Called KIB. Talked to tech support. Ordered switch and got instructions on how to remove from wall. Easy, easy.
gator
MEXICOWANDERER
For people who spud a lot, 24 gauge stainless steel is more crease resistant (stiffer) than regular sheet metal. If you an find it in 316 grade stainless the card will be unbelievably strong.
evergladesgator
Gratias.
gator
MEXICOWANDERER
REMOVAL
I commonly face this question
A "mar-proof" method is hard to find.
I have in my collection of "spud" tools a steel credit card size (thickness too) plate that is intended to slip between the panel and "wall". Gently probe around the full circumference of the panel and use lightweight pulling (prying) pressure.
Sometimes manufacturers use friction to retain a panel. You might find that you encounter "push down tabs" in which case you will have to push down and gently pry.
Very common are holes in the panel itself with cleverly disguised rubber plugs that fit flush with the panel.
evergladesgator
Thanks. NOW, how does it remove from the wall ???????????? No screws holding it.
gator
jplante4
Any RV parts store or electrical store will have those switches. It's either on/off or momentary on.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Roger10378
If it is just a bad switch get one at your local hardware store. Just get the amp rating off the bad one and get a new with the same or higher rating.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
4aSong
Generally called 'Monitor Panel'. A major manufacture of these panels is KIB Enterprises. Try doing a google search.
M & N
Tundra TRD V8 4x4 w/Leer Shell
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
Dutch_12078
They're generally just referred to as the tank level monitor or display.
Dutch
2001 GBM Landau 34' Class A
