tamberins bumpers
jackbuck
anyone used these?? opinion please
jackbuck ,2016 Arctic Fox 29-5-k ,2004 chev 3500 crew with 8100gas,Virginia.One great wife two trailor dogs,9 boys and 2 of the other kind.,all on their own, empty nest. its hard to see the picture when you are inside the frame.
9 REPLIES 9
N-Trouble
Willing to bet if you typed "Timbrens" in the little search box your will find oodles of information already discussed.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
MudChucker
I have them on my truck, they are perfect, more reliable than air bags cuz they'll never spring a leak !
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
C_B_
edatlanta wrote:
I have them on my TV. They work great and require zero maintenance. A bit over 5 years in service and zero issues.
Same here on 2003 F-250 and 2004 F-350
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
Dave_H_M
Jack, unless you have researched all possibilities for that purpose, be careful about asking a question like that cus all folks with Timbrens will pony up.
There are other methods out there in the works that provide the same service like air bags that can be adjusted to your need.
just saying,
longrider1100
So far our Timbrens have been great. The truck stays level with a heavy fiver on it. The ride is great while towing.
These are not shackles but are oversized bump stops that attach to the truck frame above the axle where the factory bump stops were.
They are most commonly used on pickups that haul salt and plows for snow and ice control. They are easy to install and we got the heavy duty ones, there were two sizes available for our truck.
Time to camp.
j-d
A number of us have bought upgrade parts from SD Truck Springs I don't know if you'll actually want to get Timbrens but SD's deal might be worth a look. Also helpful when you call them.
There's also a competing product called SULASTIC. I've heard a few good remarks about their rear leaf shackle kits for Ford leaf springs. That's not enough for an across-the-board comparison but thought I'd mention it.
edatlanta
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
jackbuck
yes =i misspelled it
donn0128
You mean Timbrens?
