โMar-16-2017 12:17 PM
โMar-21-2017 12:24 PM
โMar-20-2017 05:32 PM
hawkeye-08 wrote:clicky
You need to order a couple of these and then you can go back 30 years..
http://www.oreillyauto.com/flux-capacitor.html
โMar-20-2017 05:01 PM
โMar-20-2017 04:38 PM
MEXICOWANDERER wrote:
Well, it's like this...
I want that 11 position, snap break-before-make switch with resistor array
Configured for AGM and flooded battery voltage span.
The Megawatt voltage divider uses a convenient 10 ohms per tenth volt calibration factor.
An ON/ON 5 ohm primary bias switch can halve the resolution doubling the count to 22 positions.
While an ON/ON/ON switch can select thermistor, 11 switch or all-out 16.13 0 ohms charge rate (for equalizing).
Yeah - yeah I can use a low resistance Bourne pot to bias thereby configure the Thermistor circuit.
**** I can only wish this stuff was around 30 years ago.
โMar-20-2017 12:20 PM
โMar-19-2017 04:06 AM
โMar-18-2017 02:49 PM
โMar-17-2017 11:07 AM
โMar-16-2017 03:22 PM
