thermostat furnace issue
mclaned1
Please make sure I am thinking about this correct.
2005 prowler 24bh
Ac and fan will run perfectly but when tried to turn on furnace nothing happens. Removed thermostat to expose the wires. Connected red power wire to white wire that controls the furnace. When I connect the red wire and the white wire the furnace works perfectly
Correct me if I'm wrong the thermostat is bad and needs to be replaced
What is a good replacement thermostat for digital but not too expensive.
3 REPLIES 3
mclaned1
None taken, yes did
jmckelvy
No offense intended but you did set the furnace temp setting to something above the current room temperature?:)
06 RAM 3500,Dually,CTD,Auto(ATS Stage 1),QC,4X4,PacBrake,Spyntec Freespin Hubs,60 Gal Titan Tank,EFI Live, Line-X,Torklifts and SuperHitch,Fastguns
2013 Arctic Fox 990, 275 Watts Solar, 2 Grp 31 AGMs
US Navy 1964-1968, 2-Tour Vietnam Vet
newman_fulltime
Bad stat just go to Walmart get a digital forc20 dollars then google the wiring diagram needed depending on a Coleman or domestic
