โDec-27-2021 08:37 AM
โDec-28-2021 08:46 AM
โDec-28-2021 08:40 AM
โDec-28-2021 08:25 AM
StirCrazy wrote:valhalla360 wrote:3 tons wrote:SDcampowneroperator wrote:LittleBill wrote:Wont the heating option then use battery power?
this has been solved. they now sell bms's with heating options. When I make the switch they will be used in 0f unprotected temps.
No, the heating option is powered by the batteryโs charging source.
3 tons
If there is a constant charging source, no need to mess about with a large battery bank...which is the primary reason to install lithium.
Of course, if there is a charging source, a small heating blanket negates the temperature issue of cold.
may not be shore power they are using to preheat the batteries, it might be solar. once the batteries are preheated there is no need to keep them warm as the furnace will be warming the space there in, if they are set up properly. all the BMS does is redirect the power it recives to heating pads or what not instead of the batteries untill the internal temp of the batteries is high enough for them to safely accept a charge. but people keep forgetting that you can discharge LFP batteries in most cases to -20C so in reality you could start the furnace and warm up the rv. If you have the batteries inside the heated space, this inturn would also warm up the batteries, and all you need to do is install a disconect on your solar panels that you can leave off untill they are warm. theres always ways around cold if your willing to look for them.
Steve
โDec-28-2021 08:17 AM
โDec-28-2021 07:57 AM
pianotuna wrote:
I have room for 7 group 29 batteries. If it will fit, I'll replace the starter battery with an SiO2 as well. That ought to leave me close to 7 kwh of usable storage.
โDec-28-2021 07:54 AM
3 tons
โDec-28-2021 07:40 AM
time2roll wrote:
I don't think I could survive at that temperature unless I had continuous utility power to heat both the battery and propane cylinders. In which case LFP would be fine.
If power went out, I think I could still make the night to roll out in the morning.
I can't imagine SiO2 retains all its rated energy at that level either.
When do we get a trip report? ๐
โDec-28-2021 06:36 AM
FWC wrote:I believe he lives in that right now.
Firstly it doesn't seem like the OP is planning on going camping at -40C.
โDec-28-2021 06:17 AM
valhalla360 wrote:pianotuna wrote:
valhalla360,
Exactly so. I'll be glad when I can get to B.C. to buy 7 or 8 SiO2 batteries.
I'm still not seeing the point of your original post.
- If you need a big battery bank for other purposes but will have access to shore power during extreme cold, there are simple solutions to make lithium work.
- If you don't need a big battery bank and will always have shore power, just get the standard single battery and save yourself a lot of money.
Maybe it would be better if you lay out your use case.
โDec-28-2021 06:09 AM
โDec-28-2021 05:58 AM
Bionic Man wrote:
Sounds like a good reason to move south. I have no desire to live anywhere where those temps are common.
โDec-28-2021 03:57 AM
โDec-27-2021 10:04 PM
pianotuna wrote:
valhalla360,
โDec-27-2021 07:37 PM
โDec-27-2021 07:03 PM
3 tons
