Nov-01-2020 04:51 PM
Nov-08-2020 08:49 PM
Nov-07-2020 04:10 PM
Nov-05-2020 01:18 AM
Nov-03-2020 05:48 PM
Nov-03-2020 04:41 AM
dougrainer wrote:
I am NOT stating it does NOT happen. Just that it is NOT COMMON. WE don't do tires. But, if my customers had that type problem on new units or even USED units, I would hear about it. Doug
Nov-03-2020 04:15 AM
Nov-03-2020 03:44 AM
Gdetrailer wrote:dougrainer wrote:
I work at a medium size RV dealership. Tens of thousands of customers over the years (41 years) Probably MILLIONS of tires over those years. NOT ONCE HAVE I HAD A CUSTOMER COME BACK AND COMPLAIN ABOUT A FAILURE OF VALVE STEMS. This post is much ado about NOTHING. Doug
:R
Doug, I would have to beg to differ on this.
I HAVE "experienced" a "bad" valve stem that literally blew out in my hand while airing up the tires after sitting over winter..
Those stems came from my local tire dealer and when I took that tire to them to get the stem replaced, they DID inform me that there WAS a active recall on several Chinese made stems..
They didn't charge for the stem, but I STILL had to pay for the demount and remount :M
Had the other three tires plus spare stems replaced..
I make it a point to always replace rubber stems each time I get tires replaced, cheap insurance and rubber stems do fatigue over time and I suspect a lot of folks who have had blowouts on the road it could have been the STEMs and not the tires that were the cause.. Everyone loves to blame the tire brand or where it is manufactured but a simple dirt cheap STEM failure is also suspect but no one even gives that a look.
Nov-03-2020 03:43 AM
Nov-02-2020 12:07 PM
dougrainer wrote:I came back and complained. Sorry it was not your shop. Maybe you source better quality parts. Stems were so cracked at just 18 months they were about perforated. I handed them better stems and they gladly installed them.
Nov-02-2020 11:05 AM
Nov-02-2020 10:48 AM
Nov-02-2020 09:58 AM
Nov-02-2020 09:50 AM
jjrbus wrote:
The winner so far on damage to the coach from a catastrophic tire failure is $6200. Yes sixty two hundred dollars!
Nov-02-2020 04:13 AM
