Thanks to some previously read help from here I read this and went outside and fixed mine. Remove the four bolts that hold the end cap on, I am told they swell maybe they stick, I filed the plastic gears a stroke or 5 maybe with my leatherman. You can see where it was rubing and note the little plastic drive on one of the gears make sure you line it up upon reinstallation.
I was skeptical but mine was blowing the fuse and I squeezed the nozzle before I switched it on and it worked! let off of the nozzle a few times even shut it down and started it back up with the nozzle closed. Every ones advise worked. Thanks. good luck
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
