โOct-11-2019 12:33 PM
โOct-12-2019 03:00 AM
โOct-11-2019 08:15 PM
โOct-11-2019 02:13 PM
โOct-11-2019 01:45 PM
Old-Biscuit wrote:ScottG wrote:
No, small wire wont cause an overload message. Basically the +12 has to be shorted to ground someplace for the P2 to show that.
YEP^^^^^^
Short...
Can be at umbilical cord, plug, receptacle
Can be at Emergency Break Away Switch
Can be at ANY of the brake magnet connection
Can be INSIDE the drum where magnet wires have rubbed against shoe lever arm
OR bad GROUND
Check the brake magnet ground wire connections
Check umbilical cord plug/receptacle for corrosion
โOct-11-2019 01:41 PM
time2roll wrote:
Grab your clamp-on DC ammeter and check each wheel is getting about 3 amps when controller is applied manually. Then reconcile with the amps coming out of the controller.
No meter? Good excuse to buy a new tool ๐
โOct-11-2019 01:04 PM
โOct-11-2019 01:03 PM
โOct-11-2019 12:50 PM
