โMay-16-2022 05:31 PM
โJun-01-2022 02:09 PM
โJun-01-2022 01:48 PM
โJun-01-2022 01:41 PM
โJun-01-2022 01:02 PM
โMay-19-2022 06:23 AM
Nv Guy wrote:
This is a combination problem. Both the truck being overly sensitive and the trailer being wired poorly.
As been mentioned, the early controllers were overly sensitive. Even now they are not very tolerant of the lousy wiring the RV industry use. Specifically those scotch lock connectors and tiny gauge wiring. And let's not forget the known issue of the wiring wearing thru the insulation inside the axles creating all sorts of intermittent faults.
Once all the poor wiring is corrected, then you can start looking at the truck.
โMay-18-2022 08:43 PM
โMay-18-2022 07:45 PM
agesilaus wrote:ReneeG wrote:agesilaus wrote:
Logically since this problem is showing up on RAM and Ford trucks and we all have different RV's thus the problem is most likely in the truck connections and/or plug. Especially since it goes away for a time after cleaning the connectors.
We did that too. Cleaned the connector and it "went away" or so we thought. There was just something differently wrong. It was just coincidental that the cleaning seemed to help.
If one person reports 'cleaning' gives temporarily relief then maybe coincidence. If multiple people report that is the case, as it is here, then it is not coincidence. That is not to say that other problems might occur but the most likely is a bad connector on the truck.
โMay-18-2022 04:49 PM
โMay-18-2022 01:49 PM
โMay-18-2022 05:51 AM
โMay-17-2022 08:14 PM
โMay-17-2022 07:41 PM
ReneeG wrote:
Our problem was in the actual wheel hub. Once they pulled it, they found the problem.
โMay-17-2022 06:23 PM
Gdetrailer wrote:wvu_traveler wrote:
Thanks for all the replies. At this point I don't think its the truck but trying to figure out what it is on the trailer. May even try another similar truck and see if the same issue appears just to be sure.
The connections all look good with no corrosion. First time i've experienced this issue before.
The rub is the connections can "look good" but in reality are bad.
Typically non weather proof crimps are used to make the connections which allows moisture in the air and water splash to find its way into the crimp and wick into the wire. That moisture over time corrodes the wire creating high resistance. I would at a minimum cut the crimps, resplice the connections with outdoor rated connectors.
Additionally, axle manufacturers run the wire through the hollow axle tubes. The wire inside is free to move about which can lead to the wire breaking inside the tube or scuffing the insulation from the wire and creating random shorts.
The fix there is to bypass and run the wire on top of the axles (lots of wire ties) or run the wire back to the trailer frame and across to the other side.
โMay-17-2022 02:33 PM
