Trailer Wiring Issue
SweetLou
I have running lights, brake lights, right and left turn signals working. Only problem I have is when I have the running lights on, only the left turn signal does not work. Turn the running lights off and I have a left turn signal again. Is it a possible bad bulb? I don't have an extra to check but I thought I'd ask
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
8 REPLIES 8
SweetLou
Thanks guys. It really turned out to be a connection in the socket as was mentioned. I cleaned it up as best I could and put a new bulb in and it works fine now.
We love our Westie
WA4HTZ
It is not the bulb. Artum Snowbird described the problem perfectly. You have lost the ground connection on the left side. As Mike said, it can be corrosion on the socket but you have already cleaned that so that's probably not where the problem is. I believe most lights on RVs have a wired ground and there can be corrosion where the ground wire is connected to the socket. This would be very hard to see unless the socket was pretty rusted in that area. Also, the ground wire for this socket may be connected to the ground wires from the other lights on the rear of the RV and most connections are made with wire nuts (definitely a bad idea on something which get shaken as much as an RV does) and these can come loose. Note that when you have the running lights on you do not have a brake light on the left because the turn and brake are the same filament. Something you could try is remove the light assembly so you can get at the point where the ground wire is attached, have someone step on the brakes, and try to bridge the ground wire connection to the socket with a screw driver. If that's where the problem is, you might be able to make the ground connection and the filaments will light to full brightness. A replacement socket would be the easiest way to fix that problem. Otherwise it's in the wiring and it gets a whole lot harder to find. Sorry this is so long but I hope some of the detail helps. These kinds of problems can be very frustrating to fix. BTDT.
Ken
Ken and Jeannette
2015 FunFinder 266KIRB - Traded in
2006 Ford F-250 "Super" Cab Long Bed - Traded in
2018 Winnebago Fuse 23A
Artum_Snowbird
You are on the right track now. As I said, the power comes in the positive side of the turn filament, but lights the running filament. Take a piece of wire to a ground, and connect it to the bulb socket to prove your bad ground on that socket. The connection to the socket is the problem spot.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
RJsfishin
You are right, go buy a couple bulbs, you should have spares anyway, but that is not the problem. The problem is in the ground (neg) wire, maybe a bad socket....neg side !
Rich
SweetLou
Artum Snowbird wrote:
Nope, bad ground on that bulb. What you think is the left turn signal working is actually the running light filament. The power comes to the positive side of the turn/brake light, but the ground is not there, so it exits out the running light filament.
You can prove this by looking at the actual lightbulb with the red lens cover off. The heavy filaments are the brake/turn, and the thinner filament is the running light.
Clean up the ground by using emery on the sides of the bulb socket and the bulb itself, and see if this helps. Sometimes it is actually the connection to the socket itself.
I took the cover off and I can see both lights on and flashing but the turn signal very faint. It is a new bulb, cleaned up the connections on bulb and socket, but still does it. I am going to go buy bulbs I guess and see.
We love our Westie
1492
Moderator
Moderator
Moved from Forum Technical Support
Artum_Snowbird
Mike
corvettekent
I'd be looking at the ground wire on the left side.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
