โMay-11-2017 04:54 PM
โMay-12-2017 06:31 PM
โMay-12-2017 05:37 PM
WE-C-USA wrote:
I got everything the way I want. Moved the hot gen/inverter wire from L2 to L1. Transfer switch worked without jumper. I then reversed the L1 & L2 ( Black-Red) to the control panel (output) side.
How I only power the things I want too.
The main reason I don't want to power one side, it has- Water Heater-AC-Convertor & some outlets, things that are not used while using the 2000w inverter. I wanted the converter off while using the inverter/charger/generator. I use a Honda 2000 mainly to recharge batteries.
WE-C-USA wrote:Bobbo wrote:
I can't help wondering what the downside is for powering both sides. You don't have to USE the other side.
Yes I could power both sides. Then while using the inverter, I'd have to either--turn the Convertor circuit breaker off or install a relay. You don't want to run both at the same time.
โMay-12-2017 05:26 PM
โMay-12-2017 05:20 PM
โMay-12-2017 06:27 AM
โMay-11-2017 08:39 PM
โMay-11-2017 08:01 PM
โMay-11-2017 06:41 PM
โMay-11-2017 06:27 PM
