Transmission oil cooler for 2007 Chevy 2500HD 6.6L diesel
whs9841
I'm looking for an auxiliary transmission cooler for my truck. I've seen the PPE and BD Diesel coolers. The PPE looks very easy to install. I've also seen the Mishimoto cooler with the electric fan. It is quite a bit cheaper than the PPE and BD Diesel coolers. Does anyone have any recommendations? I'm just looking to cool my transmission oil down about 20-30 degrees. We plan on doing a lot of camping this summer in Texas and I want to get this taken care of well in advance.
2016 Chevy 2500HD Z-71 D/A
2014 Keystone Fuzion 331
DW, 8 yr old daughter, 9 yr old yellow lab
7 REPLIES 7
whs9841
I've seen temps in the 205-210 range, but I haven't pulled my new toy hauler in the high summer heat yet. I bought it last September, and it was in the low 90's when I drove it home. Since then I've only towed when it was in the 70's at the highest.
We're going to the beach a few times this summer and we might make a trip to West Texas. I figure an aux cooler will help keep the temps down, which definitely won't hurt anything. Plus, my truck is almost 8 yrs old, so anything I can do to help the old girl out will be helpful.
BurbMan
I have never heard of anyone needing an aux cooler on the GM Allison factory set up. What temps are you seeing?
chevor
I was seeing temps over 240 during climbs.
What I have experienced is cleaning the cooling stack (where the components are removed from the truck and then cleaned) can really bring temps down. Its extremely hard to clean between radiator and intercooler while still in truck. Rarely see 200 now.
I don't know if you have a the classic or new body style. I know with my 2010 the radiator came out from the rear after fan was removed. So it was unnecessary to remove AC coil and intercooler. Just washed those out from behind after radiator was removed.
The problem with the Duramax is the transmission is first cooled through the radiator and then goes to an air cooler. If the radiator isn't cooling the engine coolant effectively it will make the trans fluid even hotter.
So a plugged up radiator will cause your problem.
edbehnke
i added a pan.
eddie and sandie
3402 Montana 2013
Ford F350 2015
Trackrig
You might also want to change out the transmission oil pan at the same time to one with larger capacity and better cooling.
Mag-Hytec pans
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
whs9841
It looks like the PPE is the same as the Mike L cooler. It was designed by Mike L, but PPE put their name on it.
bob213
Heard good things about the "Mike L Cooler". Believe he's out of Inglewood, CA but ships anywhere.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
