Oct-29-2022 03:14 PM
Nov-04-2022 07:27 AM
enblethen wrote:
Have you checked your private messages?
Nov-04-2022 07:14 AM
Y-Guy wrote:
Heads up to all, including the OP, drop the insults and crude language. I'm not in the mood to play hall monitor today.
Nov-04-2022 06:57 AM
Nov-04-2022 06:48 AM
Nov-04-2022 06:00 AM
Bud
USAF Retired
Pace Arrow
Nov-04-2022 05:49 AM
Nov-03-2022 05:20 PM
Grit dog wrote:StirCrazy wrote:
if you decide to sell the rv later the new owner will thank you instead of powsting on here "I cant get my AC to work" panels are easy to change and not that expensive. at 37 years old you should replace it anyways if you are charging batteries with it, or just want filtered dc power for your electronics.
Pretty sure the market for 40 year old rolling meth labs is pretty small... I wouldn't worry about the "next" consumer to get ahold of this beauty of a trailer..lol!
Nov-03-2022 07:55 AM
Nov-03-2022 07:07 AM
Nov-02-2022 05:32 PM
TomC71 wrote:ewarnerusa wrote:
because it is simpler? The only additional thing powered would be the air conditioner. which as you said, you never run.
Simpler in the short term maybe. Not if something in the 37 year old converter/panel box goes on the fritz. This way I don't have to worry about it.
Nov-02-2022 05:26 PM
time2roll wrote:TomC71 wrote:Yes that is what I suggested but with a small automatic transfer switch to make it user friendly for all that might need power.
Is there any reason I can't just take the wire coming off the breaker for the plugs and it's negative of course, and hook them to my inverter and skip what it seems a lot of people have done?
As I said, I am just looking to power the plugs in the trailer.
I have to look to see if I have the wiring diagram for it and see if the plugs are isolated from everything else or part of another circuit.
Nov-02-2022 12:36 PM
Nov-01-2022 08:50 PM
Nov-01-2022 01:57 PM
