Trouble with leaking around toilet flange
draboo
I have a Thedfod 31112 toilet. When the blackwater tank was overfilled,it leaked from the the floor seal. I've had this problem in the past. I have three questions:
1. Should that seal on the floor prevent water from leaking when it gets over full? Or is that gasket just to prevent odors to come up and not seal from water leakage? I've had this toilet out about 4 times for various reasons and replaced the ring with a new one every time.
2. When i install the toilet, I cannot feel any compression, or seal betweenl the toilet and the ring. Could the flange be so high that it prevents the toilet from sealing?
3. If the flange is to high to prevent the proper sealing, can I find a thicker gasket to compensate? The flange on the tank is glued in, so it cannot be moved.
Thanks for any and all suggestions. I've searched online and cannot find anything about finding a thicker gasket, although I thought I did read about someone somewhere getting one from a plumbing wareeshouse.
Brad N. Myrtle Beach,SC
11 REPLIES 11
JJnLilly
The WC flange is glued to the ABS pipe that connects to the black tank. Ended up epoxying the broken piece and then used a "repair" flange over the entire WC flange. Seal between toilet and flange was fine, but replaced it anyway.
2007 Ram 2500 QC CTD
2020 Passport GT 2210
John_Wayne
On a friends MH his toilets pipe fit in the black tank with a ring gasket it was not glued into the black tank. The ring on his split and he had to install a new one. So if yours over flowed and didn't come into the bathroom area just over the black tank it may be the same.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
RLS7201
When I mounted our commode, it didn't touch the floor until I tightened the bolts, which compressed the seal. I intentionally over filled the black tank, until it flowed into the commode with the flush valve held open. The seal did not leak.
Maybe you could use 1 1/2 or 2 seals glued together.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
JJnLilly
Toilet in our unit began to wobble so when got home did the deed and removed it and found the mounting flange was broken. Flange is glued into the black tank so no real way to just r&r the flange. Looking for a good way to repair
draboo
3 tons wrote:
draboo wrote:
The last incident was caused from "friends" who we allowed to stay in the motorhome.that didn't follow instructions. So I had to rip out the flooring, dry everything out for a week, and this week am having sheet vinyl installed again.
I'm confused about how well of a seal that rubber/foam ring provides. And if you can "feel" the ring compress when you install the toilet before you tighten the bolts. I put the toilet back down temporarily today and I couldn't feel the ring compress when the toilet was sitting but not bolted down.
You wonโ€™t feel it compress - Iโ€™ve never felt mine compress, the O ring seems only minimalist-ornamental to me - trust that this malady is uber commonโ€ฆ
3 tons
Thank you for your response. I'm finally done searching. ๐Ÿ™‚
3_tons
3 tons
draboo
wolfe10
I am not a fan of wax rings in an RV, as normal going-down-the-road vibration can cause gaps.
Better are the silicone or other compressible gaskets that work with the motion of the rig.
And, none are designed to hold against PSI from an overfilled tank. For pete- sake, drain it before it gets that full!
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
stevenal
Nomad II
Nomad II
I avoid going much past 2/3, I don't want sudden braking to cause a spill.
I recently changed the flush valve on my Thetford. The kit came with a new gasket, which I used. I found the gasket easily moved off center, and it took several tries to get it right. I had to open the valve and look down the throat to see if the gasket was even. You should be able to see the extent of gasket compression in a similar manner.
'18 Bigfoot 1500 Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
Are you sure it is glued in?
One of my first posts on this forum, if not my very first one, was asking how the toilet flange came off. I think some said it was glued in, but others told me it was threaded.
On mine I think there were a few screws into the floor. After taking the screws out, I used a blunt drift punch and a hammer, rotated the flange counter clockwise out of the tank. It came out very easily when I knew how.
I suggest you try that, and replace the flange with a new one, checking the size and clearances etc to ensure you get proper compression on the new gasket.
Also check the bottom of the toilet for any irregularities. Put a small straightedge across the outlet, moving it side to side and rotating it to make sure it is perfectly even right across and not warped.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
3_tons
Iโ€™ve had the same problemโ€ฆSo I whittled down to fit snd installed a convention wax ring (i.e. wax only-no plastic) to supplement the O-ringโ€ฆ
3 tons
