โAug-06-2019 11:32 AM
โAug-07-2019 07:50 PM
myredracer wrote:path1 wrote:Dexter has the wire gauge table below. I didn't know it existed until someone posted in my earlier thread. I used automotive brake cable and the only place I could find #12 was at the local hitch shop. Not the most elegant method, but I tie wrapped it to the axle tubes and the propane pipe. The cable was way too large to pull into the axle tubes and I didn't want to pull down the coroplast. For splices, I soldered them and used shrink wrap and then tape over that. I also securely tie-wrapped the splices at the backing plates so they wouldn't get damaged from vibration. I'd rather see the backing plates designed so that the splices are inside the drum instead.
Thanks for posting. If I remember right you are into electric type stuff. For me elec sometimes a mystery. I'm going to do mine soon I hope. Your upgraded wire size, how did you determine the size? And what connections did you go with? (I was thinking of Soderling and shrink tube.
Thanks
โAug-07-2019 03:13 PM
JaxDad wrote:
There was a recent thread on the โCanadaโ section about the Ontario government backing off on the requirement that โcommercialโ vehicles used only for personal use now being exempt from the required annual safety inspection.
I pointed out how I felt it was extremely unfair, two identical trucks being treated differently based purely on who owned it.
One of the items that came up was that RVโs, boat trailers, etc., were also exempt, but even a little 4โ x 8โ box trailer was not if towed by a โcommercialโ truck.
While I have NO doubt you, and the rest of us too, maintain your RV properly, this is a PERFECT example of what I was talking about.
Forcing people to pull the wheels and check everything over once a year just keeps us all honest. No different than forcing food producers and restaurants to post the calories in the food they offer.
โAug-07-2019 09:39 AM
โAug-07-2019 08:58 AM
Thanks
โAug-07-2019 05:06 AM
โAug-06-2019 09:34 PM
