โDec-23-2019 05:46 PM
โDec-24-2019 09:23 AM
philh wrote:
Things were much easier before the TST monitor ๐ Tires were up to pressure, and then they weren't!
Tire have max pressure of 60 PSI. They were at 57 when I left MI, while driving to FL got up to a max of 69. Is this acceptable while driving? Temps were just a few degrees above ambient.
One interesting point, right side tires run a touch hotter 2F over left side.
โDec-24-2019 09:07 AM
โDec-24-2019 08:26 AM
philh wrote:In the sun they may read much hotter than that.
โDec-24-2019 06:27 AM
โDec-24-2019 05:35 AM
MFL wrote:
You say tire max is 60 psi, and 57 when you left. Normal TT tires would be 50/65/80 max pressure, or more, depending size/plies. If yours are supposed to be 65, running them at 57 will cause more heat. Towing at normal speed, a gain of 10 psi is normal. The sun side does run slightly warmer, normal also.
Jerry
โDec-24-2019 05:01 AM
โDec-24-2019 04:46 AM
โDec-24-2019 04:21 AM
Optimistic Paranoid wrote:
The max pressure is COLD pressure. The tire engineers know it's going to go up when the tire heats up, and they allow for that.
โDec-24-2019 01:37 AM
โDec-23-2019 06:03 PM
