โJun-15-2013 08:22 AM
โJun-27-2013 12:33 PM
SaltiDawg wrote:wildwest450 wrote:
It doesn't make sense that it's part of a "string" because it's the farthest light away from all other lights. The wires definitely come from the direction of the fuse box, but continue no further than the light. The other bathroom light has a single wire that come in from another direction.
Farthest geographically may not mean farthest electrically. Separate the whites and separate the blacks and see if both whites are hot - if not, it would seem to indicate the connection is simply passing power thru in a chain.
I have zero RV knowledge or experience, I was just trying to suggest some possible help.
โJun-27-2013 11:08 AM
RJsfishin wrote:
Quote:
ONE thing you need to so though is hang a meter on the wirs.. YOu may find the black lead is POSITIVE
Really ? like that mite be a surprise ? Hmmmmmm, I thought in a B&W situation, black is always positive.
โJun-27-2013 05:14 AM
โJun-26-2013 06:02 PM
โJun-26-2013 04:53 PM
โJun-26-2013 04:02 PM
โJun-16-2013 06:33 AM
โJun-15-2013 02:57 PM
โJun-15-2013 02:41 PM
โJun-15-2013 12:23 PM
Dutch_12078 wrote:
My bathroom has four wires at the light fixture in the shower, with one pair feeding power in, and the other pair continuing on to the vent fan. My old Class C had the same arrangement, but there was no fan installed. I found the wires for adding one when I removed the vent trim.
โJun-15-2013 12:02 PM
โJun-15-2013 11:25 AM
โJun-15-2013 11:16 AM
โJun-15-2013 11:08 AM
